Inverter Problem
grasscutter
East Wittering. West Sussex.
Hymer Exsis i588
Started in 1980
I have the Victron 1200 inverter fitted and linked to two 110amp eco tree lithium.
These are charged by my 400x100w solar through a Victron 100/30 mppt and a Victron 30amp B to B.
Everything works OK. Batteries are fully charged.
Problem is the inverter is cutting out under load.
I have for the past two years used a 900 w kettle no problem. Last couple of days it won’t boil and the inverter cycles on and off.
Today tried using our spin drier 240 v.
It normally draws around 55 amps on start up and then drops to around 28 amps running. Three times it cut out at 55 amps.
My logic would be that the inverter is on the way out.
Any advice would be appreciated .
Lenny HB or others.
Thanks Graham
