Mr Chrysalis
- Jul 8, 2016
- 2,392
- 333,868
- Rapido 890F A Class
- Since 2016, caravans before that, folding Caravan, tents before that
we enjoy a Tassimo Coffee first thing in the morning. I know it’s not to everyone’s taste, but we like a Caramel Latte best. We are starting to camp more often now without electric hook-up and on those occasions it’s a faff having to make an expression in the Bialetti and froth milk manually.
We have a small 300W PSW inverter to run the Skybox ( and charge electric toothbrushes). This is they type that plugs into the cigar lighter type socket by the TV. I know I cannot use this for the Bosch Tassimo as it is rated at 1.2 KW and has a 13 A fuse. The cycle to pressurise the water/steam is only a few minutes, but I don’t know what the peak current would be.
I’d like to get an inverter so we can use the Tassimo when off the grid. Someone has suggested it needs a PSW type, rated at 2kW. This is because of the electronics in the control circuit, not the heating element I assume. Is that right, or would a non-PSW be good enough, and would 1500W be enough? These need 16mm cables direct to the battery I think, so my plan would be to mount it close to the leisure batteries wired direct to a local 13 amp socket, and run a 5 m mains extension lead from there to the Tassimoin the kitchen. This keeps 12V cables as short as possible. Also what size fuse should I put in the 12 V side of the inverter?
Does anyone else use a Bosch Tassimo from an inverter?
