I am considering replacing my little 300 watt inverter with a 2000 watt one, now that I have 230AH of LifePo4.
The inverter I am considering comes with 25mm2 x 70cm long cables, which are long enough for my set up.
According to 12v Planet this size cable is 170 amps and over the 70cm will give a voltage drop of 1.53% which is fine.
I need to fuse the positive cable at the battery end.
The closest amp rating Mega fuses are 175A, which is higher than the cable rating it would be protecting, or 150A which is lower than the cable rating but also less than the max amp draw of the inverter which is about 170 amps if drawing the full 2000 watts.
Would I be better off using 35mm2 x 70cm cable, which is rated at 240 amps, and fusing with a 175 or 200 amp Mega fuse ?
