- Feb 14, 2021
- 4,864
- 11,869
- Burstner Lyseo 727G
- 3 years 30,000 miles UK and Europe.. Campsites and off Grid.
I have a 1500W (3000W peak) inverter. I use it for charging E bike and electric motorbike batteries, the wife uses a hair dryer on lower setting and we charge lap top using it. It has worked fine doing this for a couple of years.
I have just got a 1000 watt kettle and while it works the inverter beeps and shows a very low battery voltage when being used. Also the negative cable is quite warm at either end.
Could it be that the cable is not big enough or the connections not solid enough? The negative is maybe a little over 1 metre long. The positive is 1/2 metre. I have 3 90AH batteries.
