Interior light in a Smev oven
Hymer B564
Hi guys looking for a replacement 12 volt light bulb for my Smev oven,
it’s a small Edison screw thread and everything I seem to find is on 240v only ones that seem to be the correct spec are from Germany with a £6 delivery cost surely there’s a UK supplier somewhere ?
Regards The Ice Man.
Do you ever find you need to use it ?
I use my smev oven regularly and have never used the light
w2f
I just bought a small screw in bulb from asda , for the smev oven in my hymer it worked fine
And it’s a 12volt bulb from Asda ? If that’s right Asda is just up the road from me.
Do tend to use the interior light the oven as it’s low down, and need to check if the Dauphinois potatoes are browned enough 😆😆😆
Flippity Flop . . . Referee ! . . . £21 think I’ll add a PIR light opposite the oven and it’ll come on as I open the door ?
I can get the same from Germany for about £9 delivered.
Aye it was...it was a little bigger so putting the shade on was tight but did the job and only a few quid
You could try your local caravan/motorhome dealer accessories shop.
Geoff
Thanks for the link EuroTrotter will order one tomorrow only concern would be that it’s up to the high temperature in the oven but give it a go.
also popping into Asda and try to find a one that fits the bill.
thanks again guys luvin this group might even sign up as full member £20/yr a bargain.
The light in my oven does work but 9/10 times I use the torch that lives by the door!
had my one about a year I brilliant bit of kit that and a slow cooker
grate combination
 bill
