Installing fridge vent fans - connecting to Dometic controller Type P-860 Help
Riverbankannie
Bristol
IH 630 RL PVC
Trying to connect fridge fans and no handy 12v feed except that to the fridge itself. Cannot find wiring diagram for this controller.
Does anyone know if the spare spade connector in the controller is for the fans.
Alternatively does anyone have a copy of the installation instructions for the domestic fan (which is not what we have bought) but might help determine where to pick up the feed.
Thanks.
P.s. I have got the online full installation guide for the fridge but it’s not proving helpful
Here is photo, this is through upper vent and very difficult to fit airflow baffles as you can see. The water inlet is between the vents as well so even more pipes below.
I wired ours up to the 12v feed behind the fridge then ran it through a 5amp fuse (y)
How did you determine which 12v feed?
With a multi meter but it was pretty obvious which was which to be honest but I wanted to check it was constant.
Thanks but hubby a bit of a cautious pedant who wants to see a wiring diagram before touching it!:rolleyes:
I have suggested trying the multi meter on the connections...:whistle:
I just mounted a computer fan on the top vent and wired it into the van and just plug it into internal 12 volt socket when its hot and unplug it when i think its cooled down a bit,,Works perfectly,,Keep it simple,,,I have to because i don't understand technology..BUSBY.
