Inside humidity sensor
Clive G
Worthing, UK
Swift Vogue 694
Can anyone tell me where the inside humidity sensor is on my 2019 Swift 694 motorhome.
My guess is where every YOU installed it.
Not seen a factory installed sensor.
We have 2021 Kon-Tiki 599 and no factory sensor, bought a 4 pack of 2" sq Temp/Humidity sensors on Amazon.
1 in Bedroom & Main Hab area.
Does the User/Owners manual list one?
I think in the control panel above habitation door. The readings are at the top of the screen, well they are in my Swift Bessacar.
Guess you are probably rite.
Thought it maybe somewhere separate.
Sargent factory fitted somewhere
Personally given the layout on the Sargent screen, Temp in van symbol, temp and humidity without symbol I took it to be external humidity. Thought it odd as know internal would be useful when stored, but so much is odd with Swift Command/Sargent.
Currently in Seminole Florida in Swift, DIY internal read 20-25 in the 2 locations and Sargent reads 61%.
Maybe it's a question for Swift if no one has better info on whether Sargent is internal/external.
I think Smudgeer55 is saying where the humidity value is displayed in the control panel, "The reading ...." not where the sensor may be.
With the temperature sensor.
Apologies didn't read the post correctly and you are correct.
"For information only", is information not information??!! The whole Swift Command/Sargent system is an over complication/duplication of very, very simple functions and a DISASTER waiting to happen in the 1000's of motorhome inflicted with the system.
Bring back toggle switches...
Did you get an answer to your question? My one is on the floor behind the driver's seat. Combined with the indoor temperature.
