suavecarve
It says it is a sensor time out and comes with a code E503V
Any ideas
Any ideas
It's the truma inet controller and possibly something to do with gas and heating.Whats it related to?
No worries thats the reason half the threads are here to help out.suavecarve sorry to come in on an 'old' thread, but I've had this twice now and no idea why it happens. Last time I did a factory reset and that worked but just curious if anyone ever found a reason for this? I'm away this weekend and wanted some peace of mind knowing it's nothing serious ideally.
It's the water level sensor. Affects nothing else, all functions will work. But if you look at Resources you'll see it only shows Batteries, not water levels (attached photo shows both, to illustrate). It'll clear itself up after a bit, assuming the sensors are still working. So basically, ignore it and to check how much water you've got open the round red cap on the water tank under the dinette seat! Happens all the time on my rental Zefiros.
Sometimes that is so much the easiest answer !So basically, ignore it and to check how much water you've got open the round red cap on the water tank under the dinette seat!
