The indicator stalk also works the lights (side dipped and full beam) switch, rear fog light and horn. Last year when driving I switched to full beam, all other lights went out, switch back to dipped and they all came on again. I removed the the stalk and it is sealed so tried soaking it in penetrating oil over night refitted and all goof until today. Tested the lights pre MoT and it did it again. Last year when I looked at replacement it was over £100, which for a switch I rarely use I tried the over night soak. Today while getting the thing of I broke one of the clips so I need a replacement could bodge it but think new would be best. I did a search and loads came up under £20 plus a few over £120. I have one for £15 on order and one in the garage having a bath. Delivery is by 2nd Jan, MoT 15th Jan
If you need to change one on the Renault base vehicle it is dead easy - 2 star screws, two plastic clips and a wiring connector job done.
