Indicator Problem
Pulteney
Somerset
Rapido 707F
Couple of years.
Just getting my 2007 Rapido 707F Ducato based MH up together for the spring - it hasn’t been used for a couple of months and a couple of electrical warnings came up on the dash.
I managed to sort the brake light bulb by simply cleaning the contacts which were a bit grubby. The problem is with the RHS front indicator which doesn’t work. I’ve checked the bulb and it’s fine (bit of a pain having to remove/replace the whole light assembly!).
Could anybody help please as I don’t know where to go from here.
Starting point to to put a meter on the wire to see if its actually getting power
Thanks David. Problem now solved but I’ve no idea how! Checked if there was power coming to the fitting with a multimeter and there was. So I swapped the RHS and LHS bulbs and then the LHS didn’t work, which I expected. So I changed them back and initially neither worked! But hey presto first the left started and then the right! Weird.
Bit like computers then, switch it off, switch it on and it will probably work :)
