I'm in Montenegro, where to find a wheel bearing?
Jap Import Nissan4x4
Semi-newbie to motorhomes
Hi all
Currently in Montenegro and I'm heading a kind of clicking/ taping sound from the front right and i think it's probably the wheel bearing has gone
It's a 1993 nissan cabstar.
Seems like there's no nissan dealerships here and wondering any tops on the name of the place or the way to go about getting a replacement in this part of the world.
Heading to Albania in around 5 days.
It's rear wheel drive with selectable 4 wheel drive
There’s a garage called MILLENIUM about 0.5km outside Ulcinj on the main road to Vladimir and on the road to the Albanian border. I’ve used it on a regular basis when I had a holiday home in Montenegro. Very reliable and excellent prices. If they don’t have parts,they order them and they normally arrive within a few days. Worth a try. Good luck!
It probably shares the same bearing as a Renault Master, good luck with your search.
Really? Interesting. Why do you think that would be.
Ok yes never thought to jack it up and spin the wheel. Will do that first
More likely the selectable 4wd hub as they click if they get mucky or worn. Bearing would more likely squeak than click. Same set up on the navara d25 (old shape) which is likely easier to find parts for
Soz, I didn't realise yours was a 4x4. Renault Master, Vauxhall Movano and the Nissan Cabstar share quite a few common parts though.
You are confusing cabstar with primastar. Primastar is same as vivaro, Renault traffic etc. Not the primastar 1993. Sevel only started in 2002-2003 I think.
