Jane Sinclair
- Feb 5, 2023
- 5
- 0
- globescout professio
I have emptied the boiler and grey waste tank is there a valve for fresh water empty as I can’t find one
I don’t understand your reply sorryI have emptied the boiler and grey waste tank is there a valve for fresh water empty as I can’t find one
No we don’t. Is there a separate fresh water emptying valve secretly squirrels where I can’t find it?Sorry to say do you not have a handbook with a 2022 van ?
We don't have a Globecar either, but the drain tap is a little plastic wheel under the foot of the rear bed on the passenger side and at the top of the fresh water tank.I looked online for you but I can’t find any reference to a Globecar or Globescout Professional. To drain the fresh water out of the Globecar Campscout Elegance it’s under the bed on drivers’ side - access internally - there’s a pop out wood panel.
What is a whelk?Find your water tank and you should see a whelk on it, turn one way to empty and another to empty to 25%.
You tank should be in the back if the same as other globe cars.
A whelk is a wheel after it's been auto-spell-checkedWhat is a whelk?
I think a whelk is a wheel on an older motorhome when it has seized up? So needs extra mussels to turn?A whelk is a wheel after it's been auto-spell-checked![]()
Yup, I think you snailed it, even when it's fully open the flow is extremely sluggish.I think a whelk is a wheel on an older motorhome when it has seized up? So needs extra mussels to turn?
