I have a fiat ducato the cruise control works for about 15 minutes and then starts having trouble working any ideas please
Alpacas
Bessacarr
Some time the auto cruise works for a while and then I have trouble getting it back any ideas please
Make sure the brake light switch is no fouled or too sensitive as this will knock out the control.
hi i bought a 1 year old autotrail (ducato) in 2019 the cruise did not work ,,i took it to a main dealer in Preston to fix under warranty ,,it was in there for a week ,they had to strip the dash and lots stuff out before they found the problem , i just cant remember what it was ,,it was walton summit ,,could call them they give you a clue what it is ,,
You have used 4 of your 5 free posts.....then you can only read.
Subscribe and post as much as you want.
As said, it's usually controlled by the brake switch or a second dedicated switch on the brake pedal.
On my secound hand 2018 2.3 Kanus, the cruise control didn't work when pick it up, and MHdealer had to take to Fiat main dealer, who after a week could only fix it by replacing the whole control column
They are switched off by brake pedal operation clutch pedal operation or from memory if the speed drops 12 mph from wand it was set at.
Do you know if it is a Fiat system or one of the after kits?
hi that was the same year as mine ,,sounds like the same problem glad i wasn't paying for it must have cost a fortune ££
Hi it’s the fiat system Andy
Last post, you will need to subscribe now or you will be just reading the comments without being able to reply.
Best £20 you will spend and it’s been said many many times on threads as it really is true.
Solution
Had the same type of fault on my VW Amarok. Turned out to be a faulty ABS sensor front N/S wheel. Modern systems everything goes through a computer. Only found it after I bought a plug- in diagnostic tool for £134. Repair at VW would have cost double at least. Maybe a good investment for you too.
It could be several different sensors triggering it to drop out or the common fault of a bad earth connection near the steering column. That is where I would look first as it stays in for a while before dropping out
Seen maybe two of these at work. Replaced the switch unit (I mean the unit with the switches for wipers, cc and the direction indicators) and fixed both. Naturally there has been some diagnostics done first before deciding to replace it.
