I Can’t Get Gas Anywhere!
Worcestershire
Burstner Elegance
This is ridiculous! Apparently even two Calor depots don’t have any 13kg Propane gas bottles. :mad: I’ve tried nearly all the local stockists in the Thetford area and there are none! Unreal!:mad:
Southampton list them as in stock but HOW MUCH😱
Do you need a refill or a new cylinder because as Kirsten suggested, eBay can be a source of cylinders. Mind you, getting and empty one exchanged for a full one isn't easy.
Do you need a refill or a new cylinder?
Just an exchange one. Plenty of patio gas ones about but no red propane. I’m now hoping the CAMC site I’m going to in a couple of weeks has some.
Time to seriously look at fitting a GasLow (or similar) refillable system.
It will cost the wrong side of £500, but it means that:
  • The price of 11kg of gas goes from over £50 in a Calor bottle to under £8 in a refillable.
  • You can travel outside the UK for over two weeks at a time.
  • You can refill at many fuel stations around the UK, and many more in the EU.
  • You don't have the regular problem of being unable to find Calor bottles.
  • You probably never run out of gas, because when you start on the second bottle at some point that week you pass a fuel station with LPG and refill both of them to the top (used to be with change from a £10 note, although maybe not now ....)
11kg's of LPG is approximately 21 litres ( at 80% fill) at under £8 to refill that comes out at 38p a litre ?
Calor will deliver refills, usually within a few days
Literally just exchanged a 6kg propane here in Melton no problems. The compound where they keep them appeared to have plenty of 13kg exchanges.
Yep, you are right, it's now 65p a litre in the garage at the bottom of my road.
£13.65 for 21 liters.
Still thats a lot less than the £2.52 per litre or £53 for 11kgs/21 liters being quoted by Calor
Maybe give the site a call to see if they have stock,,if so, pay for it now and they should hold it for you🤞
The people who have our old van have it filled it up with 25p a litre (28 cents per litre in Belgium)
The site I’m going to doesn’t open until the end of this month! :giggle:
I guess if I go down the underslung tank route it’ll free up the gas locker so I can fill it full of leisure batteries! I already have 440ah! :LOL:
