Alistair33
All our problems are generally water related ...... but then with a surname of Flood who could expect anything less !
Woke up this morning to a water on drive under the Hymer, no frost onany of the cars or the gound. The water tank reading is still says full so I'm guessing not a lot of water has escaped, Slso the water pump was off.
On turning On the tap , I'm getting very little pressure as most of the water is being diverted to a drain point under the sink (drivers side as we are LHD), this is from both the kitchen sink and bathroom sink which are onopposite sides of the van.
Is there some sort of maybe pressures relief value thst kicks open at low temperature?
Or maybe someone has any ideas ?
Slight edit, I've now leveled the van and the tank reads 50% but hand in the leaking blue filler cap tells me it's still nearly full
