- Oct 30, 2015
- 81
- 274
- Hymer Exsis i504
- On and off for over 35 years
Does anyone know if these shower room tambour door upper “guide pins” should be a tight fit into the corrugated rectangle slots (see photos)?
Note:- I have unscrewed the upper guide rail to investigate, hence them being visible in the photos.
When in use, they only seem to guide the door around a 90 degree bend and do not take any of the doors weight?
The door looks to be supported by the lower “guide pins” the shower tray acts as the guide raiI.
I am concerned that they will eventually wear the shower tray away. Just wondering if I should glue the upper guide pins in position so that the door weight is taken from the upper guide rail.
I have seem some other tambour door threads that show the upper “guide pins” screwed into the corrugated door. Any thoughts???
The door is on a 2015 Hymer Exsis i504.
