Cornwallradio
- May 21, 2019
- 4
- 0
- Hymer S550
- since 2008
Welcome! I suspect the only place you could get a replacement door or parts of a door would be a breaker's yard. But they are likely to be very scarce if available at all. So down to DIY I suspect. Is the rest of the body sound?dont press enter before you finish your message !
So i was wondering if its possible top swap out the insulation in these doors , the actual doors metalwork is fine , its the insulation inside thats swollen and the inner door lining that on the joins where its gor wet has gone wrong....are lined ready to fit panels available for these or do i need to diy the door insulations ?
Thanks for any advice
If you upload some photos it would be easier to give advice.
Being a Hymer the insulation should be PU foam which is not supposed to absorb water.
As it's the door and not structural to the van you could take the insulation out replaced the panels and fill with expanding foam or you could replace with PU foam like Kingspan easy to get from builders merchants.
Sounds like you are taking about the wallboard/inner door panel not the insulation.cheers for the info lenny and i will do some photos and upload , it looks like original insulation in them ( a type of insulation board as you say with a textured lining / finish ) its definately a swelling from water damage i think on the middle join of the 2 part door but the s550 here has seen quite a view all weather trips i think as its well sun faded and also well weathered on the paintwork
