• Well done, you found us. THIS IS THE NEW SERVER
Hymer running light bulb (1 Viewer)
Apr 17, 2013
45
36
Bedworth
A Class Hymer Excis-
About 5 years now
Departing from Portsmouth on the ferry to Bilbao, one of the loaders said - your headlight is not working. It’s the drivers side (LHD) running light. So I asked Travelworld how much for a replacement bulb - £2500 they say - need to replace the entire unit. A headlight bulb in Halfords is around a tenner - any suggestions on a way forwards?
Sep 28, 2015
2,065
2,671
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
I put these in a few years ago, there’s probably a better one available now. My DRL’s are not on the Canbus so ordinary bulbs can be used. I assume yours are not on the Canbus also, otherwise you’d have had a dash board light warning.
A brighter white light compared to the standard 21w bulb.
Lenny HB
54,095
152,694
On the coast in West Sussex
Hymer B678 DL
Yep, standard 21 w indicator bulb. You will probably find the holder is burnt and distorted as they overheat. For now just fit a new bulb but when you get home replace both bulb holder and fit LED bulbs. They are a fairly standard bulb holder and only cost a few quid.
Mar 28, 2010
197
360
Wirral
A class Hymer 504
Since 1995
Assuming that it is just the bulb, mine cost nothing from my independent garage in February. The 'Spanner' just replaced the bulb - I couldn't reach the bulb. However if the whole unit failed, they can be eye watering. Perhaps Travelword misunderstood you.
My Hymer has the same light cluster. How to change a light bulb, and what bulb is needed, is in the manual. Like LostinSpace says, you can do it yourself - you need long, strong hands.
cliffanger
4,882
34,250
Saltford
Hymer A class
Since 2013
Cliff changed ours last week.
Standard 21w single filament bulb. Same as indicator bulb or reversing light.
You can reach it from underneath - you don’t even have to lift the bonnet. 👍
O
Apr 17, 2013
45
36
Bedworth
About 5 years now
May 12, 2011
1,197
1,873
West Midlands
Hymer
TW probably thought you had the current headlight, not the previous multi bulb unit.
I changed both running light bulbs this morning. Far easier from below, you need very long arms if you want to go in from the top. Mine are on a canbus and the led bulbs fire off a dashboard computer warning (despite being can us ready) of bulb out. I just ignore it.
Emmit
8,084
17,871
Cornwall
Pilote Explorateur
Jan.2014
Oh! How last year!
The OP didn't have the 'current' light. (No pun intended.)
Don't you just love? certain manufacturers (NOT!)
43,433
50,280
Don't forget, when it's MOT time ANY lit warning bulb on the dash which shouldn't be there is a fail.
