Hymer fresh water
where ever we park up
RV
just completed 6th year
hi all hope you have all had a good Christmas a friend has just arrived to the site I am on its the first time she has used her hymer it's just had a habital service now when the water is switched on its low pressure and water comes out of a pipe just behind the left hand rear wheel, I hope someone can help me sort it for her many thanks
Market Harborough
C Class Laika Ecovip 7R
Sounds like to frost protection valve is open. Worth trying closing it then refill and switch on the water supply.
WEST SUSSEX
HYMER B SL 674
SINCE 2005
Yes agreed does sound like the frost protection. I would run the heating - not hot water for 1/2 hour. Could also as an option put a hot water bottle over the protection valve for ten minutes, the black gizmo accessed from one of the side lockers with a blue top and blue button. It also could be the boiler drain tap is open located in the same area.
West Sussex
Malibu Van 640 LE K
Since 2003
My Hymer has 3 drain off points, one from the fresh water tank, one from the hot tank plus the frost protection valve. The fresh is at the rear the other 2 are close together near the boiler.
pepper386
RV
Thanks for the advice I will try this and let you know how I get on
pepper386
RV
Hi thanks for the advice, it was a valve by the water heater it was stuck open, sorted now nothing like what was in the manual, Thanks for help & advice
