Just going through the basics on my new purchase which is a 2003 Hymer B584 on a Fiat base.
I see the tyres need air. Whoever put the wheel trims back on have covered up the air valve but not aligning the 'hole' correctly in the trims with the valve.
It seems that I need to remove 4 of the 5 wheel bolts to allow the trim to be 'wiggled' over the last remaining 5th bolt? This bolt should remain secured to the wheel. Is that correct the correct way to do this job? (bit of a pain as my torque wrench only goes up to 150nm!)
Thanks.
Thanks.
