Googled until i can google no more! Our 1999 B640 has the L shaped sofa set up, i want to modify this so i can infil the missing bit of the "L" to make a double pull out bed. Other models seem to have what has been described as a tray holder that pulls from the side of the seat to act as a support for the back rest cushion which has a plywood insert in it to act as a bed base, the pull out is basically 2 metal tubes slotted into 2 larger tubes that telescope out by around 18 inches and support the unsupported (nearest the driver) end of the bed "extension". Im trying to source one so i can retro fit it to the L shaped seat, failing that im going to have to manufacture a pull out slatted section with fold away legs, anyone know A: what the elusive pipe thingy is called? B:Can you purchase them still?
Cheers Darren (and Marlene the B640)
