That it probably won't have much payload, it really depend on what extras have been fitted. Only way of knowing is to get it on a Weighbridge also important to check the rear axle loading as on the light chassis it's only 2000kg.If I could ask, Lenny, what do you mean by "difficult to run at 3500 legally" ?
6m van with no garage. How much payload do you need? Ok, it might be an issue if you cram 5 people in it. But it's plenty for a couple. Or did they build them out of oak 'n' iron back then?That it probably won't have much payload, it really depend on what extras have been fitted. Only way of knowing is to get it on a Weighbridge also important to check the rear axle loading as on the light chassis it's only 2000kg.
They were pretty solid all cabinet doors solid wood, weight and construction varies on year some have Fiat chassis some on Al-Ko which are 50 kg heavier also length varies between 5.99 to 6.5m. Most people uprate the 544 on the light chassis.6m van with no garage. How much payload do you need? Ok, it might be an issue if you cram 5 people in it. But it's plenty for a couple. Or did they build them out of oak 'n' iron back then?
