Hello. New here so please be kind.
Bought a Hymer Starline B510 -2001 this spring and there are two electrical faults on it.
The first error is that the 230V lamp does not light up on the control panel, even though there is power. Heard that others have the same error. This is not so critical - but why?
The second is a bit more serious: the 10A fuse called Kreis 2 blows now and then. It primarily powers the lights on the left side of the living area. It usually happens when you are driving, but it has also happened once when the motor home is stationary. Sometimes you can drive several days before it happens, but sometimes only an hour or so. Have inspected all fixtures and there are no loose wires or anything. All bulbs have already been changed to LED. Have shaken and tugged on visible cables - even under the driver's seat - without being able to replicate the fault. I myself suspect that a cable rubs or is pinched somewhere and that certain movements cause it to ground. But where? How to be able to find this? Isn't this a nightmare error? So far I have put in a resettable fuse but that is hardly the solution and I can neither hear nor see when it trips.
Advices are appreciated.
