It is wired into the solar regulator and there’s a black box inline, but I don’t know if it’s a stabilizer I’ll try and look tomorrow as it’s at the back of the cupboard.unless you are using a voltage stabiliser on the 12v supply wire, they have a nasty tendancy to fail if the voltage rises above 12.5 volts. A solar regulator will often supply 14v when charging
The app stopped working just saying connect. Tried unplugging several times then after a long time it woke up and now workingHow do you mean dropped. Lost signal?
Try switching off and back on.
