Hpc Levering System
ARTPLUM
Manchester, UK
Elddis accordo 105
Caravan for 50 years motorhome since 2019
Hi Funsters has anyone out there got a Elddis Accordo less than 6m long will HPC-HYDRAULIC LEVERING SYSTEM on so I can compare as I’m having trouble with mine. Thanks Arthur.
We have HPC on a 6m Rapido. What seems to be the problem with the setup on your Elddis?
When I use it manually on the app on the phone when you take your finger off the button it goes with a almighty bang and the motorhome shake’s it seems very aggressive
In manual mode using the app the system should just stop when removing your finger.
Who installed the system and have you had it serviced?
It’s only 18 months old it’s back at the installers now they have had it 2 months and still can’t fix it I have asked them to take it off and replace it with a new one fingers crossed that’s what they will do but at the moment they are at the NEC show it was Glide-Rite at Birkenhead to be fair they have bent over backwards to try and fix it hope that a new replacement will do the job
Thanks Arthur.
You have more patience than me!
I've never heard of a problem like this with HPC .. ours was fitted nearly seven years ago by AS Air Suspension at Warrington where we return occasionally for service and fluid change.
It would be worth a call or email to the factory at Oldenzaal, Netherlands to get their view on the problem. We went there in the early days to have the software installed for the app which at the time wasn't available in the UK.
Thanks all I’ll keep you updated as and when I get soon update from the installer
Cheers Arthur.
Only ever use our HPC on auto level 1, sometimes 2, always through the phone app. I’ve very rarely tried on manual but the front can go down quite quickly when retracted but I wouldn’t describe it as aggressive.
We’ve had ours about over 4 years now, fitted by AS in Warrington, no problems.
Hi I’ve just found your reply to my problem with my HPC Levering can you tell me who fitted yours
Regards Arthur.
Thanks Arthur.
Are you sure it is an HPC system fitted. I thought Glide Rite made their own system.
Positive it’s in there workshop now trying to sort the problem out had it 21/2 months now
