We had them . Brilliant. Might spend a fortune to get them on our current van.How are you are you finding your HPC levellers. We’re getting them installed in February at Gliderite.
Not actually been away to use them yet, but what the hell, I’m blowing the kids inheritanceHow are you are you finding your HPC levellers. We’re getting them installed in February at Gliderite.
I would suggest the rear ones are the more vulnerable in relation to kerb strike whilst reversing and rear bounce depending on overhang. I’m always very conscious of them when boarding ferries or the tunnel. I always ensure the rear air is set to full lift, giving us a further 12 inches of clearanceI'm assuming the rear ones are much more tucked away? It's just the fronts you're worried about?
Immediately behind the front wheels, it's not going to be an issue for general driving. Even road the largest road humps aren't going to be steep enough to scrape. The only issue might be if you need to drop the front wheels off of a kerb? Or reversing back up?
You’re having the same thoughts most people have when fitting this system, myself included. There is no worry trust me I’ve watched as Sue has driven over sleeping policemen and speed humps; plenty of clearance.Hi Funsters, just had HPC levellers installed on my 2022 Kontiki, this is the new series 8 cab but the front clearance when stored looks very low. There is some room above, maybe another 30-50mm but there are cables and hoses above. Anyone got pics of there’s before I die of paranoia.
Yes, had to do the same a few times. I carry a set of these which have helped me a few time on wet Temporary Holiday Sites. Lift the van up on the jacks then lower back onto these and off we go again.Very happy with our HPC kit, plus rear air suspension. The levellers have also got me out of trouble a couple of times when the front wheels got bogged down - stout timbers under the jacks then lift the wheels clear and place rocks underneath, and hey presto, traction back! I was concerned about the apparent lack of ground clearance but in practice no problems.
