How to padlock seats
Stockport, Cheshire
Bravaria i740 AClass
Hi I’m a bit concerned re security given all the recent posts does anybody have photos of wow to secure front seats with padlock ?
When I turn my seats around there is a hole where I can push through a large diameter motorcycle type cable lock, this prevents the seat from being spun around. Can’t take a picture because my wife is sat in the seat knitting.
I drilled a hole in the base plate near the edge. I think removing this lock without a key would be very difficult.
The seat is rotated and moved back for fitting. To drive, the seat must be rotated forwards, which the lock will not allow.
Hi.
While you sit indoors nursing a small pint........? Proper !!(y)
Tea Bag
A bit heavier but I use a "D" shackle intended for bicycles. Just have to be careful when fitting it, not to disturb the seatbelt cables.
Drill 14mm hole - Oxford Patriot Motorcycle Disk lock - washers to prevent hacksaw attack - whole thing will rotate if angle grinder attack.
Ingersoll impregnable padlock through steering knuckle. Difficult to access to cut off.
