How to fill twin Alugas cylinders
Glasgow, UK
Globecar Roadscout
Since 2017
We have two refillable Alugas cylinders with an external fill point and a GOK Caramatic DriveTwo Vertical automatic changeover regulator.
The GOK is NOT set to change over automatically at the moment; when we finished the first bottle (on the left), we manually switched to the second bottle (on the right).
We need to refill the bottles for the first time and I realise I'm not sure if we need to do anything with the regulator in order to fill both cylinders or if both are filled automatically (i.e. the gas flows through from one to the other).
I also don't know how to change the regulator to automatic changeover.
Help!
Just turn both bottle off before filling and you will be ok😊👍
Here’s a link with some instructions for changeover valve.
What do I do to get the regulator to go back to automatic switchover?
Thanks. I've actually got those instructions but couldn't see the answer to either of my questions!
I don’t think you need to its automatic and when you fill it will go back to which ever cylinder you use first🤔if it doesn’t it won’t matter you can still fill safely😊
it looks like you can manually choose which cylinder you use first by switching the the red/green lever the other way🤔
