If you can get 1.2 kw from any solar panels, they are not on a motorhome.my system shows 1.2 kw from 700 watts of panels
Yep. 1200W / 12V = 100Ah.Hi all in France been overcast most of the day my system shows 1.2 kw from 700 watts of panels am I correct in assuming that is 100 amps, or have I lost the plot?
That will give you the current coming from the panels, with a godd MPPT controller the current going into the batteries will be quite a bit higher as the voltage will be between 13 to 14v when charging.A few years ago, an electrician installing solar panels advised me that dividing the panel rated watts by 17 rather than 12 gives a more realistic expectation of the peak current you are ever likely to see in a 12-volt system. My own experience suggests that
The sun has just come out I'm getting 14 amps at 17.5v from my panels and 18 amps into my batteries at 13.5v.
That's a good yield from 520 wattsHere in Cheshire it was a glorious sunny day, and I got 2.4kWh from 520 watts of solar. Today it's raining. Time to go home.
