- Jul 18, 2009
- 12,382
- 21,310
- HYMER B644
so Solar/amps @ 12v for 600w / 240v is?Watts will be the same apart from inverter loses. It is the current that will change.
600 watts at 12v is 50amps but with inverter efficiency it will be 55 amps.
600 watts at 240v is 2.5 amps.
Victron rate their inverters in VA so watts will be less unless the load has a zero power factor.
Being a dyslexic old fart I had to look that word up.Edit: Lenny was more succinct.
mee too !Being a dyslexic old fart I had to look that word up.
If you can help, please?
I require 600 watts @ 240v
From a Combination of Solar and 110amp Alternator via a 105ah Lithium and Victron inverter with engine running ?
Just did a test with my 700w water heating, and multiplus 2kva. The water heating draws on AC output, exactly 695w, and out of battery, that’s including inverter, it shows a 765w DC leaving the battery. So the inv. efficiency in this case is about 90%. The efficiency It does change with different loads. Heating, resistive it’s the most efficient,or maybe simply.
How many watts @12v provides watts @240v Via Victron Pure Sinewave Inverter please?
ET
You will need to supply about 660w DC from battery, for a 600w AC load at the inverter side.If you can help, please?
Not on 12v, the only 95% efficiency you will ever see is a 5kva /48v at 70-80% load. And that with a load of power factor 1.The efficiency of an inverter is primarily down to the ratio of the load to the inverter's rated output. Most are at least 90% efficient from half power up, and nearer 95% the closer you are to its continuous maximum.
More expensive ones have extra circuitry to minimise the quiescent (no load) current draw.
Dave
I also gonna upgrade my solar when I’m back from this trip. My panels will be 2 eurener 400w. I have been searching for weeks, and nothing comes close to that choice.
Or is there something I don't quite get about using solar power?
In practice, you have a leisure bank and it is this that will power your load. Your solar/alternator need only replenish the energy that you have taken out of your battery and they can do this over a longer time period. Consequently, those do not need to be sized to power your load.
I usually work on you will need 26 amps at 12 volt dc. To produce 1 amp at 240 volt a.c.
Why you beating yourselfs up and work around it the hard way? Work in wats. Amps are meaningless without volts, and volts changes with load and charge source. So you never can account for the energy/ power in amps correctly, never ever. One amp or 60, at 12.5v will not be the same power at 13.2v. A lithium with a bit of solar can sustain a 13.2-13.4v even under load. Some heavier load will take it down to 12.7-12.8v, or even 12v if near empty. All lithium batteries have the spec in wh for a reason. Forget the ah from lead, lithium is different
You shouldn’t, the nominal voltage 12.8v is to be used, IF you make use of all capacity. If you only cycle the top part 13+ then wh is the correct measurement.TBH, I always want to use 13V but figure folks would inevitably ask why so I just stick with 12V.
However your point about Wh is a useful reminder.
Ian
What you say is true. What I would add is that It's a good idea to size your system so that the total amount of solar power harvested over the whole day is enough for your daily consumption of power.Or is there something I don't quite get about using solar power?
