How many Power station Wh = 2 hours on a generator?
Vanman
Runcorn
Roadscout R PVC
March 2017
I'm hoping that anyone can give me a clue here ...
When away at bike race meetings etc. I normally have to top up the batteries from the 2nd night onwards with about 2 hours of generator per night. I'm thinking of replacing the generator with a Power station but haven't a clue as to what size I would need to cover x3 nights of 2 hours. I'm guessing that the EHU set up only takes power at the rate that the batteries (2x 110) take charge, but that's about as far as I've got ...
I've been looking at the Anker 256 Wh or 512 Wh battery packs 🤷😳
Thanks!
Globecar Summit 540
I'm no expert but
You shouldn't be running the batteries below 50% so charge from 50% for both is 110ah. Multiply by 14V = 1540wh. So you would need a bigger power station. And that would be one day, you would need to recharge the power station or have one twice as big for the next day......
Edit- it takes you 2 days to drain batteries so I guess you could halve these numbers, but same result- bigger power station!
Isle of Man
Autotrail Cheyenne
Since 2015, still learning
My advice, from experience, is that if you have the space and don’t need to use the genny anywhere else, then add a bigger battery / lithium. A decent sized power station (2000 wh) is >£1.2k. Just my experience. My 767 is about 160 ah.
sleights
c class
Thanks!
I think it's easier to look at the discharge rates for the existing batteries than look at the charge going in. For example if they are going from 80% to 60% you are using 20%of 220ah so 44ah. Your power bank would need 3 times that at least. The good thing with a power bank is you can recharge them relatively quickly assuming some mains power is available or you could have separate solar. If everyone else is also using a generator it could be you're better to carry on with that as you wouldn't annoy anyone
Vanman
Vanman
Runcorn
Roadscout R PVC
March 2017
Thanks, I only have a small van with no more room in the battery location. Changing the whole system to Lithium is probably never likely to happen so I'm looking at something than can live most of the time in the 'garage'.
Vanman
Vanman
Runcorn
Roadscout R PVC
March 2017
Thanks for taking time to post that, it’s made me think. Part of my problem is the Van control panel for the batteries, it only has x4 lights for 13.5v (charging) 12.7v (full?) 12.2v (needy) or 11.0v (in trouble) so as soon as it drops below 12.7v it shows 12.2v even though it could be 12.6v really.
I just checked my batteries and they are 2x95Ah AGM – 190Ah
So if I assume that my batteries are going from 100% to 75% most days off EHU that’s about 50Ah used. These Power stations seem to be sold in Wh and if Amps x Volts = Watts the 50Ah x 12v = 600Wh. If those figures a anywhere near then I might be able to get by on the 512Wh model if I keep my beer fridge turned to low, and to off if necessary.
I’m planning a trip to Le Mans next year and I’m a bit wary of taking the generator and spare petrol to the EU, through the tunnel etc. I do have a bit of Solar so maybe being in France will help too! Do these figures 'add up'?
Herts.
Adria Coral lowline
I’m surprised you only get two days from two batteries. We have two batteries, there are two of us, 7.5m van, plenty of lights in it. No solar, no B2B, and easily get four days.
Possibly asked above, but how old are your batteries? Ours are 4-5 years old.
