I made a little bracket with a screw so I can keep button in or have it working normallyHave a 2012 hobby Toscana 650. Found it has the usual truma dump valve prob. How do I stop from dumping water in minus deg so I can fill tank
Do you keep it nice and toasty?I made a little bracket with a screw so I can keep button in or have it working normally
That’s brilliant!!!I made a little bracket with a screw so I can keep button in or have it working normally
Now now boys the toaster was the mk1 method to keep the valve closed keeping it on low but what with the price of electricity I had to come up with something else.That’s brilliant!!!
Frost comes, button pops out forcing screw into toaster elements, which then short out, burst into flames and puts the button back in with the heat!!
Absolutely brilliant!!
Just why ?
The frost valve won't open if the the vans in use and if it's not in use your hot water bottle will only be effective until it gone cold, about half an hour
We've had the dump value open during the night even though we have gone to bed with the water at its highest temperature. Heating and water were turned off overnight.You must be very hardy, lol.
If you have the boiler on for hot water in the evening, I'm sure the residual heat would be enough to keep the valve from opening overnight
Heating on, but thermostat turned right down, which leaves power to the dump valve without heating the MH......................for those hardy souls amongst you. I'm obviously not one of them ,especially in these current temperatures.How do I stop from dumping water in minus deg so I can fill tank
Cheers,
Jock.
It may depend upon which dump valve is installed.Power to the dump valve? Don’t think there is power to mine.
Strange, I thought they were powered permanently, whether your 12 volts was turned on or not ?Power to the dump valve? Don’t think there is power to mine.
I was a sapper too but now I've retired I've stopped sleeping in the cold. Others may not know what we're talking about. Sorry but can't help with the Truma problem because it's going to snap open if it's not in use. Not sure that holding the button in is the best idea since if water does freeze in the tank it will probably be damaged. Ring Truma and ask them as their technical guys are very helpful.Yep. But when sleeping in the van (away in it for 5 nights over Christmas) we like fresh air with roof vents open. Even during this cold weather in the house we’ve got two windows open as we like lots of fresh air.
I’m guessing there’s potential for it to drop pretty cold, in the van, this time of year.
Strange maybe, but that’s how we sleep.
Continental vans it's a standard fitting UK vans it's optional.So, the mechanical valve is fitted on the water outlet as an option, so this must mean you can retro fit one if not already installed? My previous van had this option, new one hasn't.
My dump valve went tits up, so I replaced it with a manual drain valve. But, I religiously empty all my water after returning from a trip or if away in the winter and the forecast is below 5 degs, I will leave the water heater on low or the heating on, set low, better safe than sorry.
We had this happen when we drove to Helmsley for a couple of nights on the Aire they used to provide. We went fully loaded knowing there were no facilities. Parked was setting up the heating and hot water, turning on the gas and filling the kettle. Heard this pouring water noise and so got out and checked round the van to find water pouring out. We lost half the tank thanks to the damn dump valve. After that we used a paper clip to keep the valve from operating when out and about! Worked perfectly. Always removed it when back home and parked up. Always drained down the system too.Just why ?
