How do you reboot a sargent ec 200 in an autotrail chieftain. Thanks.
Big yin
Auto trail chieftain
How do you reboot a sargent ec 200 in a autotrail chieftain
Take off the bezel and unscrew the screws. Then disconnect the wire for 30 secs or so.
Or if you can find the uses that feed it you can remove them.
Thanks will try that. My problem is the unit is not charging my liesure batteries, any ideas.
Could be a few things.
Fuse to the batteries blown
Charger knackered
Batteries kaput and not holding a charge
Get a cheap voltmeter stick it on the batteries.. Switch on the charger and if volts go to 13-14+ then charge is getting to them
If not then work your way back to identify the culprit.
Then I'd start with fuses.
When hooked up to mains can switch ec 200 on but after about 30 seconds the 3rd trip MCB3 trips can turn it back on and about 30 secs it will trip again?
Try with each appliance turned off then add one by one. Possibly heater?
Or is it only when charging? Try with charger fuse out or charger switched off.
MCB 3 is for the fridge, charger, boiler and 240 lights (if fitted) according to my manual. If batteries not charging, could be a fault there. You should be able to turn the charger off with the button on top. Perhaps reset the breaker and turn each one on in turn until you find the culprit. Hope it’s not your charger
