- Sep 25, 2023
- 733
- 926
- Swift Sundance 590RS
How do I remove the pipe from these. One is leaking but no idea how to disassembly
What Lisa said, blue bit should just be a cover to stop anything from moving the retaining clip so pipe can come out.Stick a flat screwdriver in the indent and flick off the collar and then you should be able to see the push/fit collar that you pull back as you pull the pipe out.
