I had to replace our hab sealed lead-acid batteries and now have 2 x 150Ah gel batteries connected in parallel. They are connected to the cab battery via a relay, I assume that is ok?
Our charger is a Numax 122000 which I believe is unsuitable for gel as it mostly uses a constant current charge mode and gel needs a constant voltage, is that correct?
What size and type of charger would you recommend I get?
TIA
Martyn
TIA
Martyn
