Hot water system
T-line 743
We have a t line 743 and wondered whether it's normal for the shower to produce about 3 mins of hot water, even though the water tank has been heated for the alloted time!
Newcastle under Lyme
Hymer B544 A Class
Since 2015
No, that's not right.
What heating system / boiler have you got and how are you heating the water.
Oh and ......
w2f
Two on Tour
Elddis Autoquest 175
Since 2010
Are you just leaving the shower running as you may do at home then the hot water will not last for long, or using the motorhome method of wetting yourselves then switching off the water and soaping up, then switching the water on and rinsing off, plus we use an eco shower head to save water.
Worcestershire
Bailey Adamo 75-4t
March 2018
Yes. Wet your body, soap, rinse. There is only 10 litres of water and that will not last long if left running.
Wiltshire, UK
Ducato Sportivo
Since 2005! 2000+ nights so far...
If 10L tank, at full temp (70') - then mixed with cold at 20' , thats 20L @ 45'. Pump 6 or 8 litures per minute = 3 minutes.
So sounds normal if you are using it like home.
Trigger shower heads are great - and we can easily get 2 "good" showers
Take a look at the manual - but that says 2.5l flow which is quite low but easy enough to measure your flow.. You could "slow" the flow down, or trigger shower head (though the later MAY need NRVs on hot & cold to prevent spikes)
