Hot water heater (3 Viewers)
Apr 6, 2024
10
11
AutoTrail Imala 615
We are never sure whether you are supposed to leave your electric hot water switch on whilst on site (as long as there is water in the tank of course) or whether you just switch it on when you need hot water in a little while and then switch off again. We have had conflicting advice in the past and just wondered what Funsters did on site?
Sep 25, 2023
750
935
Swift Sundance 590RS
We always leave ours on. The the internal theromstat keeps the temperature at a constant 70°. That said I find that very hot. On gas we can adjust the temperature. 60° is more than enough.
Nanniemate
6,759
46,671
IH
I turn it off , I would leave ot running at home so why on site
If we all turn off things when not in use maybe sites could be a little cheaper with ehu
We can also save the environment
Oh and
World peace may be achieved :wink:
750
935
How. The more heat cycles it goes through the less time it will last. It certainly won’t make it last longer and wastes electricity. Do you continually boil your kettle at home?
I guess your gas boiler at home comes on every day, so I don't see your argument. The internal Thermostat takes care of the boiler so it is not on all the time, there is about a 10 Deg temp difference on the boiler, at least there is on ours. On Gas I can adjust the temprature down to 40 Degs if needed. It takes 20 mins to get to full temperature on electricity so likely using more energy and heat.
7,249
13,291
Herts.
Adria Coral lowline
My home boiler comes on twice a day. Just before morning showers, and just before evening showers. So it is the same as whilst in the van. I don’t have home boiler on whist I’m on holiday, during the night, or whilst at work as it would waste power.
Nanniemate
6,759
46,671
IH
There are some thoughts that it cost more to turn on and off than keep at low temp when out.
If I'm cold I turn it on if I'm smelly and need wash turn hot water on
Lenny HB
56,072
164,155
On the coast in West Sussex
Carthago Compactline
The problem with Truma Combi's is the Eco setting heats to 40° then turns off and does not turn on again until the water temp is below 27°.
4,651
10,365
South Lincolnshire
Rapido 7065+
Broken most bits now
If I’ve prepaid for leecy or it’s free at home the water goes on permanently. Sadly only on 1 bar on most euro 6 amp sockets
643
2,598
Maspalomas, Spain
Giottiline Toscan 74
I don't see a problem with that, however, I am in the Canary Islands where it is forever hot (and I'm sick of it). So I understand that you guys in sub zero temperatures need the hot water HOT. Sorry, I realise that does not help 😀
750
935
Not only a waste of power but it will need descaling more often & scale build up will make it less efficient.
In 22 years I doubt anyone has descaled ours. From cold we get 70deg hot water in about 20 minutes, thats pretty efficient for a 22 year old MH. If I use gas at the same time for a hot water boost that time drops to about 15 minutes or less.
Heating elements going from hot to cold, hot to cold will suffer more than keeping a steady temperature.
9,829
26,135
Derbyshire
Elddis Accordo 105
since 2014
We switch ours on in the morning for our showers (take note Richard n Ann) on ECO mode, I have no idea what temperature that might be, but it is sufficient and then switch it off again till next day.
We use the shower blocks. The van shower is only a wet room type, it's OK but a little cramped, it keeps us clean on the way home when all the French sites are closed 💫
643
2,598
Maspalomas, Spain
Ah, I'm glad about that. I thought you were saying you didn't shower for 5 weeks 😂 sorry for the misunderstanding.
