Hi, I’m away at the moment, the blow heater from my Truma C boiler is not blowing out a lot of heat, it’s on full, the water is fine any help would be appreciated
Martin
Martin
Have you checked the various connections in the ducting system as sometimes they can come apart and you could loose some heat from there. Also it's worth checking for splits in actual ducting. Just a thought.Hi, I’m away at the moment, the blow heater from my Truma C boiler is not blowing out a lot of heat, it’s on full, the water is fine any help would be appreciated
Martin
