With the increasing costs of wired internet connectivity, I am after some thoughts on maybe moving from virgin internet to a 4/5 G system.
According to this site https://www.broadbandspeedchecker.co.uk/ I am getting @ 65-80mbs download and 10-25mbs upload on my iphone on Vodafone so a reasonable enough signal for streaming, browsing etc.
Having though about things, I can fix an external antenna to the front of the house which I can connect to something like a RUT 955 Hub.
Our current virgin hub is in the centre of the house in my hallway. Next to it there a wall mounted 4 port Ethernet connection plate , which feeds an office upstairs , our lounge and dining kitchen,. I don’t know where the 4th port connects to.
I could run cables ( Ethernet or cables with SMA connectors) from the antenna to the hallway without too much difficulty. Distance is approx. 9m.
If I run the cables with SMA connectors I could plug straight from the hub to the wall ethernet ports. If I put the Hub upstairs close to the antenna and run an ethernet connector, I think I will need another ethernet hub to connect into the wall ports. Rough drawings attached.
If it works, the hardware and cost of a monthly Sim card should pay for itself in about 18 months over the cost of Virgin/ BT etc.
My thoughts with the Teltonika would be to get a Vodafone 100 or 200GB sim which I could use in the van when away. I would have a second sim 5-10gb just to keep monitor the security cameras when away.
Any thoughts on the above?
Thanks for looking
Thanks for looking
