Hobby 750 Control panel (2 Viewers)
sailorjoe
Hobby 750 FME
Hi all,
As a new owner trying to rescue a 2000 Hobby 750 I have, at the end of a long day, popped out with a lever the rocker circuit breaker thinking it's a fuse I can check, wrong, and now it won't reset. I've removed all power no luck. I'm stuck, it's for the main lights.
How can I get this circuit breaker back in as it was fully functioning before I interviened
grasscutter
2,577
10,032
East Wittering. West Sussex.
Hymer Exsis i588
Started in 1980
Hi and welcome.
Sounds like you have damaged the mechanical action of the breaker.
If you can access behind the panel a temporary solution may be to fit an inline fuse to protect the circuit.
Hope you get it sorted.
Hopefully others may be along with further advice.
S
sailorjoe
Hobby 750 FME
Thanks I think so to as the circuit will not complete if pushed in, held in with a toothpick, no lights so internal damage seems likely. Advice is needed on removing the whole panel above the door, it's well constructed. Any Hobby 750 owners help on thisšŸ˜Š
883
2,452
Nantwitch Cheshire
A Class N+B Flair
25years
I would try Hobby owners club uk then Hobby club Germany thereā€™s a lot about in Germany many very old ones so a good source of knowledge.
