Jonathan=B584
Hi – I'm a new Hymer B584 Classic y2000 owner and I have a peculiar problem with the 12v electrics. With all the van side circuits off (including the switch above the door and in the Electroblock), I have a draw on the leisure battery of over 2 Amps, as measured by a multimeter at the battery. This increases at times for no apparent reason up to 5 Amps. Interestingly, if I completely disconnect the battery, I measure a 1.8V voltage in the circuit.
Removing the leisure side fuses makes no difference to the draw, nor does removing the vehicle fuses in the cab. The leisure battery is new and the vehicle battery starts OK and holds a charge. There is usually solar feeding the leisure battery, but I physically disconnect the solar charger from the battery for the above tests. Any ideas. Thanks in advance.
