Help with setting up a VPN (29 Viewers)
Jul 5, 2013
11,880
14,004
Since 2013
I have a Huawei mifi and 4G roof aerial which works well for us in Europe and we were getting UK TV programmes easily. Last spring we had plenty of data via IQ Go, but that has now sadly stopped. Therefore I am planning to buy pre-loaded local short term SIMs to put into the mifi. As I understand it that will mean that I will need to use a VPN in order to get UK TV.
So my question is how can that be installed in the mifi? I suspect we will be getting more than one local SIM as we move around, so does the VPN need to be reinstalled each time I change the SIM?
Can I get a VPN that works for short periods or do all of them want a year's subscription? And finally what VPNS can you recommend for simplicity and cost?
Both of us have 12Gb roaming each from Smarty, which will be OK for calls and everyday browsing. It is the TV coverage will need more.
Many thanks for your help
Oct 18, 2021
2,401
7,305
Mid Devon
Adria Compact SC
Camping since 1954, MoHo 2022
Do you use a Firestick? Although I setup to use NordVPN on our router (Teltonika unfortunately so can’t help with your specific question) I’ve since found it easier to control and use when on individual devices, including the Firestick, phones, tablet and laptop. IIRC a Nord account allows up to ten devices within a family to be connected.
246
440
Etrusco CV540 DB
Are you using a smart TV? If so it is unlikely that you will be able to install the VPN app directly on the TV. This means you either have to VPN enable your router, or, as has been suggested, use a device like a Firestick plugged into an HDMI port on the TV, so long as that device allows you to install your choice of VPN app on it.
I use a Beryl router with my Starlink and it is possible, though a bit techie, to enable this to use my Surfshark VPN service. It may be that you could also do this with your router, so I would suggest doing some Google searches
The choice of VPN is also very important for streaming as all are not equally good at evading detection by the streaming companies. We use Surfshark which is a sister company of NordVPN, and this works well for most services. We have used it successfully for Netflix, iPlayer, ITVx, and SkySports app, but it didn't work with Amazon Prime which detected a VPN in use and refused to play.
Nov 4, 2011
6,397
44,463
Uk
I have a ZTE MU5001 and unfortunately you can’t put a vpn on that but I just run Surfshark on iPads, iPhone and Firestick.You can buy different periods but the longer you buy the cheaper it is.
I’ve found that iplayer wouldn’t work with surfshark but changing to ‘small packet’ that sorted it.
Jul 6, 2009
2,136
2,690
We use Express VPN, easy to instal, use it on firestick no problem with all channels and Amazon.
