Help with gas issues
Mercedes Tristar
Mobilvetta New Life
MOBILVETTA 59 PLATE MOTERHOME OVEN & FRIDGE UNIT ISSUES - GAS HOB LIGHTS OK, OVEN LIGHTS BUT NOT TURN UP + FRIDGE WILL NOT WORK ON GAS- ADVICE please
I would say two separate issues. Oven burner probs needs replaced and fridge.....well I'd send it to a dometic repairer for service and repair.
Also fridge will have an ignition put your ear to fridge you should hear the ignition trying to light it. If you put pictures on somebody on here will be more knowledgeable. The oven burner with some use might pull around a bit.
