Help with CBE panel
Steve and Denise
Spalding LINCS
A Class Carthago
Since 2008
I am looking to find a ignition + on a CBE DS450ra panel I have looked at a diagram of this and was thinking of trying to splice in some where to get a feed for a relay to isolate the hab batteries whilst the engine is running.
The reason for doing this I have fitted a B2B a friend at Newark said use the fridge supply I think I have found that but am a bit warey as the panel looks expensive if I get the wrong one!
Steve
If it is anything like my 520? it is connector 25
If correct it will only have a voltage with the engine running
Spot on Techno!:thumb:
Its good to have other teccy minded people on here! It saved me looking!:BigGrin:
Cbe 450
Thanks Tecno
That panel looks to be a different layout. The wire I think it is seems very thin though.:Smile:
Steve
Give Rob Leafe at Automate a bell. He's based near Newark but could come out to you. Im sure he'll be able to put you right. His office number is 08456 529501 and mobile 07800 591216. Tell him you know me and Lynda. He's just sorted out a whole load of problems on our van only today.
PS Are you going to Whitby?
Cbe 450
Hi Ken
Thanks for that I will do.
No wont be at whitby this time we are planing to get up there in August for the folk festival and we will be at MHF Dorset meet :thumb:
If you are at Peterborough I'll find it for you Steve.:BigGrin:
The cable is quite thin, there is no need for the D+ cable to be any thicker. The relay coil only takes a few milliamps, so no problems!
Cbe 450
No Jon thats not the one it is a CBE DS450 ra what I will do is fit the relay and pull a wire through ready to connect then it is just a matter of connecting.
I would post a pic from the net but not sure how to copy and attach it.
Steve
Steve
You could use the satellite dish connection point, D+ should be the green wire.
I've just used it to isolate my electric awning.
Was just about to start a new thread asking if anyone had this. (y):D
I know this is an old thread but I'm looking for a user manual for a DS520 distribution box. I have seen the two pictures above but I'd like the complete manual which include the connection and block diagram of the unit.
If someone could either upload to resources or PM me a copy, I'd be grateful.
Chris
Chris
You should be able to download a user manual from Marcel Leisure.
Hi ,
Yeah I've downloaded the manual for the DS300, which is the retail distribution panel. but the 520's seem to be specials for van builders.
Have you seen a link for a DS520?
Chris
Oops It looks like you posted and PM's, I did reply to your PM(y)
Chris
