Help, Tail light not working
Wirral Peninsula, Wirral, UK
Hymer Tramp
Since 2018
Bulb ok, fuse ok but not reading 12v so asume a break in wire. Anyone know how to detect where break is(gadget) and how to fix. 2005 Hymer on a fiat base, any help appreciated 👍
Sounds like you have a multi meter, in which case if you know which cable is the 12v feed, then follow it back a few inches, push a pin or sowing needle into the cable to make contact with the wire inside, and then test between the pin and chassis and see if you get 12v. If you don't get 12v then move down the cable away from the rear light fitting and test again with the pin until you find 12v.
Most rear lights feed to one side and then link across the back of the vehicle to the other light cluster.
Sounds like a plan 👍will look when rain stops, cheers, sorry hubby will look when rain stops and he's fixed the broken blind 😀
My Jokon branded rear lights/indicators stop working every now and then and it's usually tarnishing on the lamp contacts that's the problem and a quick scrub with a glassfibre pen usually sorts them, but I'd try taking another voltage reading using a decent earthing point on the chassis before I started looking for breaks in wires ?
I should (if you can) pull the spade connection off the light fitting and push it back on, they sometimes corrode a bit and break contact, did on mine recently
Good job you haven't got a
BM Troubleyou
Sons m1 lost his rear lights all others working.
I tested system best I could rear light clusters all good no rust mildew etc. (like new)
Bridged across from fog light + lights working.
All pointed to module but didn't have time to do inspect it. New one coded £500+vat😢
So he booked into
BM troubleyou rip off service dept £125 per HR had it all yesterday. "no sir not the module its the light cluster"!! Both sides £135 each
Oh well he has his own credit card now 😁
