Help please Truma heater combi 4
transit
Hi guys getting the flash code on Truma Combi 4 it’s llsllssl I’ve googled it it’s says Combustion air motor faulty
  • Cable harness faulty
  • Fault in I’ve checked all motors there runing fine only thing i can see is a bit of corrosion on the pcb board would this be coursing my problem thanks in advance
Here’s a photo of the pcb board
Have you tried resetting it using the reset button on the actual PCB board. You need the heater set to come on then press and hold the button in until the lights change the rate of flashing
Hi thank you for reply I’ve pulled the board out and my one don’t seem to have a rest button
I have a bit of corrosion on the board the code comes bk as 217 I’ve attached a photo of the damag ex do u think this could be the problem
