Help needed
East Sussex, UK
Euramobile 770hs act
2023 very newbie
We have recently purchased a 2004 eura mobil activa 770 HS. And we have no idea how anything works , including the habitational control .we have no paperwork/ diagrams for anything and no owners manual . is there anybody that could pass on their expertise, so we could at least understand the control panel. And maybe where we can purchase a German owners manual. Thankyou
If you post photos of your control panel and any other bits you need help with I'm sure someone can help.
Although there may be no one with the same motorhome, all these bits are used in many others
Hi , thanks for your reply , I will try and post pictures now , i just hope I post them in the right section, as I'm new to this forum , thanks Michelle
I
If you can use your phone or IPad to take the photos then post them on here via the attach files on bottom left of post.
We have recently purchased a 2004 eura mobil activa 770 HS. And we have no idea how anything works , including the habitational control .we have no paperwork/ diagrams for anything and no owners manual . is there anybody that could pass on their expertise, so we could at least understand the control panel. And maybe where we can purchase a German owners manual. ThankyouView attachment 771820
Have you tried to contact the previous owner or dealer?
Its in Dutch page 18 but copy and paste and translate to English, I hope this helps
Thankyou so much nanniemate, this will be a great help .your a star
I think you may have to cut and paste it onto a word doc and then translate depends on what system your working on Good luck
from top left on off switches for Panel
Prog button you can set time or timer or language control or tones press prog then up or down buttons
V press once for habatation battery twice for engine battery
A amps using
Press water button once for fresh water twice for waste
Temp press once exterior temp twice interior temp
Mode pressing prog button then up down arrows mode set to that one
Then on right to two are gas which we don’t have working
On bottom left tap is on of for water on on right is jab electrics on off
I’m away at moment but when I get home will email the pages to you I’m home next month
