Hi all on the Forum ..
As a " newby " on this forum , Hello , my name is Dave and having just bought a 2009 Fiat Ducato 3ltr diesel 6 speed auto box , all was good for a week or so
then an engine management light appeared .. code was PO 6308 throttle actuator control range performance bank 1 ..
seems to be a common fault , especially on this model .. due in some way because my Motorhome has spent most of its life parked up
going nowhere then the occasional run to the coast .. sooting up ..??..
The camper has only travelled K48000 miles .
I took it to a local garage who plugged it in to a big boy code reader and he now tells me the following ..
U1602 .. Can Bus Off
U1700 .. NBC Node Absent
U171A .. refer to OEM repair information for code description
OBD11 .. Codes ( $03 )
OBD11 Permanent Codes ( $0A ) Codes
he has told me to contact an Auto Electrical Engineer
I must add that it starts fine and drives like a train , no apparent loss of power .
Apparently in laymans terms its an Electrical Fault .. Engine Control ( NCM ) .. Auto Trans ( NCA-NCR ) .. Fault with engine control module .
So do I take it to a FIAT Dealership or hunt around for a top notch Auto Electrician .
I really do need some sound advice please , any and all appreciated ..regards Dave .
