Help! My bottom hinge is stuck, any suggestions?
North London
Adria Compact SP Aut
Since 2008
Any suggestions please
my bottom hinge had seized
I have done the WD 40 etc.
The top of the hinge moves and I can take it off, but the bottom one is stuck solid.
If you take off the top half can the central pin off the hinge be tapped down so it comes out of the door section.
I would expect the centre is furred up with some oxidation.
if you can separate the three sections you can run fine emery paper inside the central section to remove any detritus then lubricant of silicone or graphite!
Apply a bit of heat from a hairdryer to see if it expands, don't use WD40 as its a water dispersant hence the WD, light oil or silicone oil or firstly a good dose of penetrating fluid or very light oil and let soak
You have probably made it worse by using WD40. Most of that type of hinge has a nylon bush and WD40 makes nylon swell so you will probably need a new hinge.
Thanks I was a bit unsure whether to tap it down as I didn’t want to break it . I will try it tomorrow
WD40 original is not a lubricant, many people make the same mistake, it is a water dispersant (WD). WD40 is the last thing you should use on any MH or Caravan moving parts. Use silicon or PTFE spray. Silicon is not good under load, PTFE is finer and better suited.
Luckily I don’t think I have damaged the hinge with WD 40 as I sprayed it on the inside -she says😭😭 I have drowned it in Silcone spray. I tried to take off the outside hinge but couldn’t so may take it to a garage tomorrow as I don’t want to damage the screw head, a speciality of mine.
Can’t believe this has happened as my old Adria Maxivan rear door hinge seized up and needed replacement 😭😭
Thanks I have drown it in Silicone Spay but will have to wait tomorrow as can’t get off outside hinge
Funsters to the rescue they are amazing 👏
Silicon does not penetrate very well if its seized. Better to try a proper penetrating oil first. Give it a few days to see if it works first though.
I remember years ago using stuff called "Plusgas". A bit of paraffin oil is an alternative if you have any sculling around.
What type of oil do you suggest?
I have always used PlusGas - https://www.plusgas.co.uk/en-gb - but after a quick search have just realised that there are quite a few variations on the penetrating oil theme so if you're interested, you can lose a little time reading this:
WD 40 will loosen your hinge to get it off. Once off clean your hinge up and give it a rub with wire wool. Reassemble using using copper slip, Silicone grease etc, Then never use WD 40 again as it will strip any grease off anything you have put it on.
