HELP!!!! Hymer high level brake light replace
darach2
hymer
Replacing the high level brake light on my 2020 B580MC Hymer.
2 small screws, the light comes off but when I pulled it away from the body one of the wires has disconnected in the back of the panel, there is only a small hole in the panel so no access there.
Inside behind the rear cabinets there is a large black plastic cover, does anyone know if this comes off to access the cables?
Or any ideas?
Derek
Sorry I can't help, but welcome to the forum.
Maybe a picture would be useful for others to advise you?
Only had experience with older Hymers but there's usually a way to access from inside, although it's not always obvious or simple.
Hymers of the 20 teens had this as a known problem.
They all need replacing.
The solution is to remove the old light and solder on a new light.
Hi , Thanks for all your replies. I stripped the side cabinets in the rear area and pulled the rear cabinets forward. Not easy.
Found where the wires came through behind the rear cabinets. Easy enough then to fit the light and connect inside.
In hindsight if you had known where the wires were it might have been possible to fish them down but the way I did it is probably the best way, although if I had been more careful on the outside I could have connected the wires there.
Thanks again.
